Please help with DPF OFF file MB B180CDI 2006 edc16c32. My EGT sensor is damaged.
Ive tried some solutions, ASC. Swiftec but car still in limp mode 3000RPM and error B19/9 still present. Also the car is automatic and due to limitation remains in automatic mode.
The error on sensor B19/9 exhaust temp sensors voltage high is present with both original and dpf off file.
If anyone can help with dpf off file for this ecu with OBD2 reading and all dpf related sensors please help.
Thank you
Free doesn't exists, Chep doesn't last
Thank you. Its ASC2017 solution. doesnt work. Error with EGT sensor high still present. Car rpms is limited to 3000RPM
Hi, confirm the possibility remove DPF without dpf pressure and temperatur sensor.
Try.Good luck.
@mvekas sorry friend but i wouldnt dare write this into ECU
edc16c31 dpf solution works ok, on edc16c32 not
