Cheksumm error in ecu eeprom.
I'm working with Bmw E46 320d. Car no crank. When I try to sync ews3 with dde7 it appears fault "Ecu rejected".
Interface - Inpa, ncs expert. In ecu still i see fault 4A42 - ews interface error.
Can somebody sync for me these files?
I appreciate any help.
Thank you in advance.
Magicmotorsport Flex Full, Magpro2, Swiftec, Winols, full ETL, Carprog and others....
atd (24th March, 2018)
Are you able to count this cks? or give a hint which software make this. ?
read flash from dme. 29fXXX post it
BMW FOREVER
I programmed bram380's dumps. Engine didn't want to crank. Then I made new key, engine cranks but no start. In ews seems to everything ok, in dde two faults 46D1 and 4A63.
Could it be hw problem or checksum problem in eprom?
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Car started everything now is ok. Thank you for solving the problem.
I used ews3 dump from bram380 and helped me kiszka's dump for dde with counted checksums.
In my situation 46d1 fault were caused because of bad checksum in 95160.
One more time thank you guys.
kiszka (24th March, 2018)
