your dtc off
good luck
your dtc off
good luck
it's my pleasure to help you
quikcar (19th March, 2018)
same problem just dtc off
car without power rpm 3000 t/min max
can somone have other solution
thx
try with this and report
P0227 - Throttle/Pedal Position Sensor
did you check the pedal sensor?
try this file
REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
