Results 1 to 15 of 26
    rtvservis's Avatar
    Default suzuki grand vitara 2008g 1.9 disel
    nead dpf remuwe
    0 281 012 657
    sv 1037381585
    i have 2 option on ads dpf remover v2017.05
    edc16c3-ddis
    edc16c3-10
    I did both options. can somebody look up. which option is ok
    if not ok pleas som to du dpf off .
    thenx
    rtvservis's Avatar
    Default this software
    it is working i didnt tested
    chipdanix's Avatar
    Apr 2016
    Poland - Warsaw
    Nobody one knows everything we learn a lifetime
    repair ecu , dtc , dpf , egr ..........
  4. The Following 2 Users Say Thank You to chipdanix For This Useful Post:
    rtvservis (21st March, 2018), stanislav georgiev (21st March, 2018)
    Sep 2016
    So I see all solution for this car and check him in winols, all is bad, cut dtc with temperature sensor EGT turbo pressure, when he destroy car sometimes not have power and off course not dtc in ecu. Only manual solution is good, all temperature sensor must disconnect and emultead, differetnial pressure always have 15mbar pressure. This is my opinion
    FILE SERVICE
  6. The Following 2 Users Say Thank You to voltechcar For This Useful Post:
    rtvservis (29th March, 2018), stanislav georgiev (21st March, 2018)
    rtvservis's Avatar
    PROBLEM CAR NOT START EROR INJECTOR 2. AND .3 AND 4 .
    ON ORG FILE CAR WORKS VITH DPF EROR
  8. #6
    johak's Avatar
    here you go
  9. The Following User Says Thank You to johak For This Useful Post:
  10. #7
    furnata's Avatar
    Bulgaria
    Here your file working
    pass PM
    Im here to help and to be helped
  11. The Following User Says Thank You to furnata For This Useful Post:
  12. #8
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    just checked, ddis function is allmost good..
    just this one EGT sensor is wrong for me...
    DSG TUNING
    File Service
  13. The Following User Says Thank You to maajkii For This Useful Post:
  14. #9
    rtvservis's Avatar
    johak file demage can send again
  15. #10
    maajkii's Avatar
    Mar 2017
    use new winrar..
    DSG TUNING
    File Service
  16. #11
    Sep 2016
    if you need good solution not automatic software write to me, I cut 3 dtc and emulated all sensor. This is my solution and works great
    FILE SERVICE
  17. #12
    rtvservis's Avatar
    still have problem with this car . i need SVIFTEC solution pleas
  18. #13
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    try this and report pass in PM!
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  19. The Following User Says Thank You to AVDigitale For This Useful Post:
  20. #14
    maajkii's Avatar
    Mar 2017
    Quote Originally Posted by rtvservis View Post
    here is your request...
    pass pm.
    DSG TUNING
    File Service
  21. The Following User Says Thank You to maajkii For This Useful Post:
  22. #15
    rtvservis's Avatar
    Default solewd working thenx
    solwed with sviftec file. programed file off dpf with chipdanix file. the car worked for two days. then the motor ecu ded. found the motor ecus of reno lagune 0 281 012 588 memorized flash micro and eprom. the car start does not have any faults.
