Results 1 to 3 of 3
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Default Need help FIXING bmw ABS module,soldering copper??
    Hey all..There was a thread for abs modules here,very helpfull but i cant seem to find it..
    So,anyone that fixes these modules,i came across this,and as i was experimenting,these very very small wires,like hair were cut.
    is there any way to solder anything there??
    Regular solder does not feel good next to copper :P
    So i cant do anything..My experience is not so good.
    How do you do it?
    Apr 2016
    holland
    you must do it ultrasonic soldering this is not by heat but by vibration
    Ultrasonic soldering is a flux-less soldering process that uses ultrasonic energy, without the need for chemicals to solder materials, such as glass, ceramics, and composites, hard to solder metals and other sensitive components which cannot besoldered using conventional means.
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    I managed to do it,by soldering very carefully tiny wires..
    Abs module works again..
    It took me 2 hours to do a clean job.
    But of course thank you for your answer.
