Results 1 to 15 of 26
    eepromdom's Avatar
    May 2017
    Based in villieria, Pretoria. South africa
    Default Freelander 1 immo off.
    Hey guys... I was wondering if its possible to immo off this damn freelander I'm busy with... Its a mixed set and I'm unable to program it. There are fuse box and wiring config issues too.. It would be easier just to bypass... If possible.. Included pls find zip archive with flash and serial info. Thank you...respect..freelandr1 moto.zip
    Sent from my LG-H850 using Tapatalk
    no passwords here..i aint trolling for a gold star.. love this forum
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    uid 3,2 i think like mems3 can do it, but need some wires cut, and 8bit read e2p.
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  3. The Following User Says Thank You to Pyromaniak For This Useful Post:
    eepromdom (22nd March, 2018)
    eepromdom's Avatar
    May 2017
    Quote Originally Posted by Pyromaniak View Post
    When I read 8 bit I get exact same checksum brother... I can do the mems units and I cut pin 13 immo line and earth the starter relay side from ecu... These moto boxes are different.. But you're right ... Immo line must be cut... Not a stress... I read on 8 and 16 bit and auto id e2rom... All had the same file with same checksum... Does that help you? Or I will send 8 bit also tomorrow... But its the exact same file... No info is swopped or anything... Wellon compare reveals no changes between 8 and 16...
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Programmare la EEPROM 93C66
    (Read and write a 8-bit)
    Tagliare(cut) il Pin 72 della ecu.
    Tagliare il Pin 23 (rosso e nero)red black
    dall'IMMO BOX e unirlo(connect) al Pin 2 (nero)black
    sorry for italian i copy from program
  6. The Following User Says Thank You to Pyromaniak For This Useful Post:
    eepromdom (24th March, 2018)
    Feb 2018
    Germany
    100% work pass pm = thanks
  8. The Following 7 Users Say Thank You to kalinin2018 For This Useful Post:
    atakan (8th September, 2020), eepromdom (24th March, 2018), ivarf (5th January, 2023), PtiCin (23rd June, 2021), taxo1965 (18th May, 2018)
  9. #6
    Mar 2018
    Hello, i need help, Freelander1 02 year, ecu MS43, immo sawdoc, need kill immobilizer. It s possybly?
  10. #7
    eepromdom's Avatar
    May 2017
    Quote Originally Posted by deman1 View Post
    Ms43? Siemens? Like the BMW? Yeah sure I can do those...send flash dump...
  11. #8
    Mar 2018
    Freelander 02year, auto muffled and no longer starts, the starter rotates, there is no spark and injection, ecu MS43, immo SAWDOC inside pic 12f252. When the ignition is turned on, the petrol pump works, When I scroll the starter, I see the speed of the scanner and the petrol pump turns on and turns off when I stop turning the starter. I removed the connector from the camshaft sensor, I twist the starter of turns on the scanner, I do not see, the gasoline pump starts to work constantly. I sin either on the immo or on the crankshaft sensor, but the new sensor costs 96$, I do not really want to buy for the sake of experiment for that amount. Tell me who knows in this issue how to be what to do? the flash subtracted is 29f400.
  12. #9
    keturi's Avatar
    Oct 2010
    Lievatu
    Help, please to make immo off for Freelander 2005, 1,8 petrol, Motorola NNW504210.
    Files 8 and 16 bit attached.
  13. #10
    Feb 2018
    Germany
    Default immo off
    press thanks please
  14. The Following 5 Users Say Thank You to kalinin2018 For This Useful Post:
    bboctavian (19th September, 2019), eepromdom (23rd April, 2018), keturi (17th April, 2018), PtiCin (23rd June, 2021), taxo1965 (18th May, 2018)
  15. #11
    keturi's Avatar
    Oct 2010
    Lievatu
    What could be wrong? With original eeprom engine starts and stops after 1 sec, so with immo off file not starting at all. Any ideas?
  16. #12
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Quote Originally Posted by keturi View Post
    try else solution.
  17. #13
    keturi's Avatar
    Oct 2010
    Lievatu
    try else solution.
    No have another solution, all known done, think need tested manual eeprom mod.
  18. #14
    firestator's Avatar
    Oct 2010
    MINSK
    if you want to repair a car, I can help you with this! welcome to my skype
  19. The Following User Says Thank You to firestator For This Useful Post:
    keturi (25th April, 2018)
  20. #15
    keturi's Avatar
    Oct 2010
    Lievatu
    Thanks and Reputation done On your skype already
