Results 1 to 15 of 19
    Sep 2013
    garage
    Default Opel Astra H 1.7 z17dtj Denso DPFoff
    i need a dpf off file for astra h 1.7 cdti z17dtj Denso ecu ...read by mpps 1Mb file . Thanx
    Jan 2018
    shaftesbury,Dorset,UK
    Quote Originally Posted by Mr BLACK View Post
    there you go mate, test and let me know
  3. The Following User Says Thank You to kennyash1 For This Useful Post:
    Mr BLACK (22nd March, 2018)
    Sep 2013
    garage
    something is not ok ....no dtc but glow plug light is flashing ..........
    Jan 2018
    what error do you have? with original map... hold on I will try to fix
  6. The Following User Says Thank You to kennyash1 For This Useful Post:
    Jan 2018
    here you go mate please let me know
  8. The Following User Says Thank You to kennyash1 For This Useful Post:
  9. #6
    Sep 2016
    all he's maps not work and you have light on. In this ecu first use sps and up sw to new, next reset dpf. Than edit file and last ..... coding dash to without dpf. This my sugestion.
    FILE SERVICE
  10. The Following 2 Users Say Thank You to voltechcar For This Useful Post:
    Mr BLACK (22nd March, 2018), stanislav georgiev (22nd March, 2018)
  11. #7
    Sep 2013
    garage
    i have no dtc with original map car was buy with no dpf and glow plug flashing with no fault code ....
  12. #8
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    standard
    need to decode dpf from instrument cluster, than reset dpf again, and working soot not growing, no glow plug bulb again.
    DSG TUNING
    File Service
  13. The Following 2 Users Say Thank You to maajkii For This Useful Post:
  14. #9
    Jan 2018
    is it doing it as soon as you turn the car on? as soon as engine is fired 2-3 secs then flashing ? if so this sounds like turbo actuator fault. actuator arm should move when engine is started? im guessing electric actuator?
  15. The Following User Says Thank You to kennyash1 For This Useful Post:
  16. #10
    Jan 2018
    these guys know more than me I had no idea you had to decode from dash
  17. The Following User Says Thank You to kennyash1 For This Useful Post:
  18. #11
    Sep 2013
    garage
    i use pin code and i code ipc with no dpf i reset dpf in ecu ...now glow plug light is off....but i do not know for how long ...
  19. #12
    Sep 2016
    works when you have emulated temp sensor to big value and differential apressure have value 0
    FILE SERVICE
  20. #13
    Sep 2013
    garage
    temp sensor to what value ..car have 2 sensors .. ?.....300 ..or higher 350 ...400 ?...dpf is removed from cover ...so persure must be 0
  21. #14
    maajkii's Avatar
    Mar 2017
    temp sensor - 350 for example
    pressure - 0
    than all ok.
    we find also solution without decoding DPF from dash...
    working like a charm.
    DSG TUNING
    File Service
  22. The Following User Says Thank You to maajkii For This Useful Post:
    Mr BLACK (23rd March, 2018)
  23. #15
    Sep 2013
    garage
    a software solution ....?
