Results 1 to 11 of 11
    jodge's Avatar
    Mar 2017
    Default BMW 2010 F10 problem
    Long story sorry
    - My customer is a car dealer he need a spare key
    - I started the car and noticed to him the car battery is almost depleted
    - he removed the car positve battery cable in the trunk
    - After that i removed the CAS4
    - He connected his battery charger to the battery (cable still unconnected)
    - He just closed the trunk
    - I readed the cas eep with vvdiprog, all fine (not cypted 1L15Y mask) but before noticed the solderings marks (probably the eearlier owner does some dash work)
    - I put back the CAS4 (still unconnected battery) and left the place bcose i have to working another place and he is with customer
    - Later he tried to connect to the positive breakout in the engine bay with a portable jumper (trunk closed battery still unconnected)
    - finally he diassembled the trunk key hole cover and manually opened the trunk and connected the batter back.
    - and maybe he does more thing but he admitted just this two thing on the phone
    Only the parking icon working on the dash nothing more. The orig key isn't working and i'm a bad guy now
    I think he just messed up something with the charger/jumper
    The spare key isn't programmed yet, and i don't want to until the car not starting with orig key
    I have to visit him tomorrow morning any thoughts?
    thx
    yes it can be that you have corrupt the file by reading the cas.
    but can also be that the file get corrupted by removing/connecting the battery.
  3. The Following User Says Thank You to vageric For This Useful Post:
    jodge (22nd March, 2018)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Upload files D and P flash
    Dont see problem is you backuped. Write ori files and check.
  5. The Following User Says Thank You to drugowaz For This Useful Post:
  6. #4
    jodge's Avatar
    Mar 2017
    Okay the problem is probably the corrupted CAS4?
    And the two possibilties are the juper/battery thing and the prommer.
    The next step tomorrow is reading again the whole CAS and comparing with the backup?
    Well i think i made a huge mistake i have only the d-flash
    What possibilities are i have?
    thx
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Your mistake always need backup both
    First compare D flash if they are same. Post pic of cas i think someone will put here suitable p flash for test. If only p flash corrupt so no big deal.
    Check fuses offcourse
  8. The Following 3 Users Say Thank You to drugowaz For This Useful Post:
    Akslock (23rd March, 2018), jodge (22nd March, 2018), rola1971 (23rd March, 2018)
  9. #6
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by drugowaz View Post
    Here is the full backup and the label picture, the first readed eeprom dump (dflash) and the second attempt is identical.
    Could anyone check pls the pflash?
    thx
  10. #7
    That is why I always do the job from begining to the end and cars like F-series only in my shop. Looks that you have a problem because pflash looks OK.
    It's good to use search
    http://www.digital-kaos.co.uk/forums...-4-1l15y-flash
  11. The Following 2 Users Say Thank You to EMCE159 For This Useful Post:
    fytfh (24th March, 2018), jodge (23rd March, 2018)
  12. #8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    check all fuses in all modules,connections near battery positive cables. locate all modules by bmw wds if you not have rheingold
    do diag also.
  13. The Following User Says Thank You to drugowaz For This Useful Post:
  14. #9
    Oct 2017
    The two files are totally same
    https://drive.google.com/open?id=1Ye...TMwqhx4Qn_kUfC
  15. The Following User Says Thank You to Sasika For This Useful Post:
  16. #10
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by EMCE159 View Post
    First of all thx the help. I really appreciate it.
    The car jumper result is some blown fuses a half dead battery and lot of DTC. The car is strating now
    In the future i never i wont let anyone to touch the car while the key learning wont be finished.
    It was a good lesson to me.
  17. The Following 4 Users Say Thank You to jodge For This Useful Post:
    bersch8688 (24th March, 2018), drugowaz (24th March, 2018), EMCE159 (24th March, 2018), Weasel3 (24th March, 2018)
  18. #11
    I had the similar situation in past, good that car is running.
