Results 1 to 11 of 11
    Top Poster mack0r's Avatar
    Mar 2017
    Default Astra H edc16c39 dpf off
    Hello, does anyone have the correct solution for this ECU? Does ASC do it correctly? I do not like ASC programs because they delete almost the entire DTC table ... Can someone help?
    Jan 2018
    shaftesbury,Dorset,UK
    Quote Originally Posted by mack0r View Post
    here you go buddy, please let me know
    Mar 2017
    Quote Originally Posted by kennyash1 View Post
    This is ASC Solution. No Good because delete many many dtcs
    dominik.m's Avatar
    Jun 2009
    POLAND
    If you know, that it is bad , then improve manual. Or use different programme they would solve problem.
    Mar 2017
    Quote Originally Posted by dominik.m View Post
    I have already done dpf off in a few cars and always manually but I do not know this ecu and I am looking for the correct solution and that is why my question.
    dominik.m's Avatar
    Jun 2009
    POLAND
    Upload Your ori file.
    Mar 2017
    This is ori
    Jan 2018
    This is ori
    solution works well for this ecu have used on many customers cars with no issue with dtc delete..
    very easy to make dpf off Manuel with this ecu if you have done on others? may I ask what ecu you have made dpf off for then?
    I can aid you with Manuel delete
  9. The Following User Says Thank You to kennyash1 For This Useful Post:
    mack0r (23rd March, 2018)
  10. #9
    Mar 2017
    I dont remember but manualy in ecu edc16 in vw, audi, BMW, citroen, peugeot. I dont do dpf off manualy in opel cars. Your solution do dtc off about 70-80%. Its not good.
  11. #10
    mancioks's Avatar
    Feb 2017
    Germany
    Here u go. DPF off with manualy deleted DTC. Pass pm
  12. #11
    Mar 2017
    Ok thanks i check file later
