Wiring is ok ? Did you check ? Number srs unit ?
Hi folks.I heave problem with Pug 308 T9 2014y.There is airbag problem lexia showing a B00DF 11 dtc it means that deacivation switch of passenger airbag is faulty.Allready replacaced this switch but dtc stays on.Enyone has dealing with that issue?
Please dear members push the button if my work was helpfull!
And reputation button(star)
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
drewdom (22nd March, 2018)
Disconnect this airbag and join resistor 2,2ohm or 3,3ohm and try clear errors ...
Best regards.
Dragon
drewdom (24th March, 2018)
Problem solved it was a wire from switch crashed betwen two metal parts of body.
