Results 1 to 15 of 25
    Dec 2012
    South Africa
    Default Ford Figo Millage
    Hi Good Day all Good Helping friends
    Can someone please change km to 135990
    Ford Figo Original 328000 plus minus.zip
    Thanx n million
    dump bad................................
    shooting's Avatar
    WALES
    Quote Originally Posted by Frederik View Post
    Thanx n million
    Your file was HEX saved as TXT,
    to help you I converted it to BIN
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  4. The Following User Says Thank You to shooting For This Useful Post:
    Frederik (23rd March, 2018)
    hex --> bad
    bin --> bad
    Dec 2012
    South Africa
    Quote Originally Posted by shooting View Post
    wbr
    Thanx so much friend. Did u made the odo correction as well?
    Sent from my S60 using Tapatalk
    Dec 2012
    South Africa
    Default I Managed to resave it
    Mr Nikz please try this one Ford Figo ODO 24c16.zip
    post #4.................
    Dec 2012
    South Africa
    I saw what u ment by bad dump in the first file ive uploaded. The second file looks pretty much the same as the others.
    Any idea what to do please please
  10. #9
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Mate read properly ur file have only half data ......Ur car starts ?........dont try to write any other file if u write u will loose ur data and the car will not start, remove the eeprom from the pcb and read properly and post the dump to edit km.
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
  11. #10
    Dec 2012
    South Africa
    thanks zcakria
    i see what u mean, ive allready wrote another dump so im screwed? any help/idea???
    the FoCom give me pats error and car not start. Another dude helped me with a incode but FoCom Rejected it.
    I Need to start this car please HELP ME
    Im sitting with only that top half of the file
  12. #11
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    u need to programme Ecu and cluster and need to make key with it. If u have key programmer i can give u the ecu and cluster data, ur car is diesel or petrol ?
  13. The Following User Says Thank You to zckariya70 For This Useful Post:
  14. #12
    Dec 2012
    South Africa
    Quote Originally Posted by zckariya70 View Post
    I dont have anythin good. I only have the top half of the dash file. I have a ck100 auto key programmer but its crappy. I have carprog. Cant we immo off the car? Or any sugestion. Should i buy a zed bul mini?
  15. #13
    Dec 2012
    South Africa
    Petrol
  16. #14
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    petrol its easy, remove the ecm u will see 93c86 inside remove it and make key with my dump and write eeprom back to ecm and write my cluster file in ur cluster and start the car. simple...............
  17. The Following 3 Users Say Thank You to zckariya70 For This Useful Post:
    Dr. Zoidberg (23rd March, 2018), Frederik (23rd March, 2018), Johnner (23rd March, 2018)
  18. #15
    Dec 2012
    South Africa
    petrol its easy remove the ecm u will see 93c86 inside remove it and make key with my dump and install eeprom back to ecm and start the car.
    Thanx so much you a geniune star. I will strip it now and see what i can do. Ho do i make a key from that dump
