Ford Figo Millage - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Dec 2012
    South Africa
    It doesnt allow me to download the attachment my fiend someting about privalidges
    Quote Originally Posted by zckariya70 View Post
    petrol its easy remove the ecm u will see 93c86 inside remove it and make key with my dump and install eeprom back to ecm and start the car.
  2. #17
    Mar 2017
    Colombia
    It is better for me. file good on board, do synchronization with Ford vcm online. The computer seems like a lot of time to uncover it, better all by obd2
    WINNER THE LOSER
  3. The Following User Says Thank You to automotrizVIP For This Useful Post:
    Frederik (23rd March, 2018)
  4. #18
    Dec 2012
    South Africa
    Quote Originally Posted by automotrizVIP View Post
    Lol why better for you. I dont have a vcm only a FoCom without tokens for incode
    Sent from my S60 using Tapatalk
  5. #19
    Mar 2017
    Colombia
    of delays, 35 minutes approx for obd2 .... doing in the banko 2 hours aprox .. without counting that you can damage something if your pulse is alzheimer "jeje "
    Edit; correct...
    Alzheimer to... parkinson
    WINNER THE LOSER
  6. #20
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    alzheimer
    You wanted to say Parkinson, thank God you're not a doctor .
  7. #21
    Dec 2012
    South Africa
    Quote Originally Posted by Dr. Zoidberg View Post
    Thank you very much guys wich me luck im gonna attempt this today
  8. #22
    Dec 2012
    South Africa
    Hi Guys sorry i took so long to let you know whats going on
    Ok so i cant get the ecu out of the car as the centre bolt on the connector is a sheer off type.
    So im still battling.
    Will u be able to edit a dump for the cluster if i have the as-built data from ford?
  9. #23
    Mar 2017
    Colombia
    you had already used vcm ...
    you would have delayed less I told you..
    only if you get internal code .. but I think it's impossible
    WINNER THE LOSER
  10. The Following User Says Thank You to automotrizVIP For This Useful Post:
    Frederik (29th March, 2018)
  11. #24
    Dec 2012
    South Africa
    Thanx mate. I only have vci. And it does bot support programming new modules to a car. I can keycode with the focom aoftware but not module swop.
  12. #25
    Dec 2012
    South Africa
    Aby Idea how to remove ECU Centre Bolt
