Results 1 to 15 of 15
    Mar 2017
    Default Virgin MEV17.4.2
    Hi friends, I need help to virgin this psa ECU
    mev17.4.2
    0261s06472
    thanks for help
    kazoula55's Avatar
    Sep 2012
    Sep 2015
    HELLO , I NEED PASS HEL ME PLEASE
    Apr 2011
    I am after a virgin file for the same ECU, MEV14.4.2 0 261 S06 472. But mine as TC1767 inside.
    Any help would be appreciated.
    Jul 2017
    Quote Originally Posted by lunchb0x View Post
    Use Ktag for read and post your dump
    Apr 2011
    Read with hextag. files are attached.
    Thank you.
    Jul 2017
    Thank you.
    Hi ! Try and report
  8. The Following User Says Thank You to Tanjona For This Useful Post:
    lunchb0x (30th November, 2020)
    Apr 2011
    Quote Originally Posted by Tanjona View Post
    Hi ! Try and report
    Thank you for taking the time to help.
    Unfortunately I am not able to test it, I can read/ write the ECU fine on the bench but in the car there is no communication. I tested with a different ECU and that does communicate, so there is an issue with my MEV17.4.2
    Thank you any way.
  10. #9
    Jul 2017
    Thank you any way.
    Please Correct the checksum first. I don't know if Hextag do it automatically, but I used Ktag wich correct checksum automatically
  11. #10
    Apr 2011
    Incorrect checksum I should still be able to communicate to the ECU in the car though won't I?
    I can read and right the ECU on the bench no issue.
  12. #11
    Le-Mans's Avatar
    Jun 2017
    possible and immo off if you want!
  13. #12
    Jul 2017
    You think your ECU is died ?
  14. #13
    Jul 2017
    You think that your ECU is dead ? Try to write original dump and see if you able to communicate to the ECU !
  15. The Following User Says Thank You to Tanjona For This Useful Post:
    Stelaras26 (12th December, 2020)
  16. #14
    Jul 2017
    How about your ECU ? I resend file with corrected checksum
  17. #15
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    No without correct checksum,you cannot communicate with ecu by obd
    If i Helped you,use thanks and rep button to thank me back
  18. The Following 4 Users Say Thank You to Stelaras26 For This Useful Post:
    lunchb0x (14th December, 2020), Meat-Head (12th December, 2020), speedservice (12th February, 2021), Tanjona (16th December, 2020)
