Results 1 to 3 of 3
    Kic's Avatar
    EU
    Default Astra H CID 3 Line update
    Hello!
    I tried to flash my KS CID with a BN firmware.
    I moded the 93C66 EEPROM with BN info (just the IDENT area) then manually inputed BN VIN during SPS and
    GlobalTIS v32 allows me to update the FW from CD53 to CD83.
    The update starts but it fails around 50% showing 424109 Bytes reprogrammed (of 812978).
    I tried Mongoose cable and Tech 2 both pass-through and remote mode, both failed on the same spot.
    Reverting back to original EEPROM and flashing a KS FW (CD53) back works OK.
    Is someone willing to share and point me in the right direction?
    Kic's Avatar
    EU
    Problem solved.
    You need to use a older version of GlobalTIS (v25 solved the issue in my case)
  3. The Following User Says Thank You to Kic For This Useful Post:
    MNenad (31st October, 2019)
    Aug 2014
    HI
    I want to update my Astra H CID to 3 lines....can you share with me how to modding dump to BN ident .
    PM or here?
    Thanks anticipated!
