Results 1 to 15 of 25
    Newbie obd2help's Avatar
    Oct 2016
    Default volvo xc60 acc not working after mil correction
    Hello i have a problem i have a Volvo xc60 2014 let somebody do the milage on it with dp4
    over obd now the acc adaptive cruise does not work in instr clustr say wrong data reeived
    dont have backup so cant pu old file back what i tryed is disconnet battery for hour and alligned th acc after that was working for 2 miles and gave error acc not worig cmmuncation error wrong data received
    is there some one hav same expuirience and give me a hint how to solve
    Nicolas9's Avatar
    Feb 2017
    Aruba
    probably data corrupted.
    if you don't have backup, I'd search for another dump file and work from there..
    maybe best to use another device to change mileage on this specific car..
    (I'm not a diagprog4 specialist but I've used it a couple of times.. doesn't it automatically backup if I remember correctly??)
    Oct 2016
    yes he sad also dp4 makes backup automaticly but in this case there was no backup or the dude did not now to find it
    brend's Avatar
    Oct 2015
    Same where
  5. The Following 3 Users Say Thank You to brend For This Useful Post:
    hayk57 (24th February, 2021), intelect200 (26th January, 2021), obd2help (30th March, 2018)
    pierre renault's Avatar
    Jan 2013
    disconnects the driver's door plug
    Oct 2016
    what do you mean by disconnect drivers door plug
    you mean before milge calibratin or just unplug itnow nd then plg t bag?
    Oct 2016
    here a picture of the dash
  9. The Following User Says Thank You to obd2help For This Useful Post:
    patrick1112 (3rd June, 2019)
  10. #8
    brend's Avatar
    Oct 2015
    Same where
  11. The Following User Says Thank You to brend For This Useful Post:
  12. #9
    Oct 2016
    Default files xc 60
    here are the readed files from the cluster the dude that did milage did read it after with jtag unsecured
    didnot do itby mysel hope these are good readfings
  13. #10
    Oct 2015
    I now what is the problem. Yor car have active cruise control and it's not possible make this car bloking dash cem
  14. #11
    Oct 2016
    what to do to make it work again?
  15. #12
    Oct 2015
    You need to put the original flash in cluster afther this the cruise control will work again the problem it's the old km will jump back.
  16. #13
    Oct 2016
    thats the problem we dont have a Original backup maybe some one can tel me where to get a Original file ?
  17. #14
    I tried to repair your file
    and also sending another working file from XC60 but MY2013.
    WBR, Marek
  18. The Following User Says Thank You to tech_cz For This Useful Post:
    obd2help (21st June, 2018)
  19. #15
    Aug 2015
    You can repair it with vida just make a dim reload
  20. The Following User Says Thank You to offsystem For This Useful Post:
