Results 1 to 7 of 7
    Mar 2014
    West Sussex UK
    Default Programmer for Nissan Leaf
    What programmers are working for Nissan Leaf? I use Zed-Full for most of the later Nissans but every time I try and program a smart key on a Leaf I just end up with I-Key error on the dash and the original key won’t even work. Battery disconnect for a few minutes gets the original working again but can never successfully add a key.
    super jumbe's Avatar
    Livingstone
    Truecode, Handy Baby ....
    p1et's Avatar
    Oct 2013
    Maybe Londsor K518, people haveing many success with new Nissan cars with this tool. But this is just my guessing.
  4. The Following User Says Thank You to p1et For This Useful Post:
    fricker (2nd April, 2018)
    Sep 2016
    EASY diag work.... error you see but if you close door and turn on error disable and wery work if algoritm program a key is trye
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by Cromwe11 View Post
    i make new key in Lonsdor.2017 leaf all key lost
    10 min job
    all work
  7. The Following User Says Thank You to rola1971 For This Useful Post:
    paul_12345 (17th October, 2018)
  8. #6
    Sep 2015
    Quote Originally Posted by rola1971 View Post
    10 min job
    all work
    Zedfull does work to program leaf. We have done 100+ Leafs, very easy and fast job, it even works on the new 2018 model.
    What we do is to just ZF to turn off the electric steering wheel lock, it will find bcm, convert to pin and turn off steering wheel lock in one process, then you dont have to use ZF anymore, just register keys.
    push button with key logo so dash comes on, push buttom again to dash goes off, click unlock, if thats the last key, finish with lock.
    doors must be closed when doing last key and finishing programming with lock button on key.
    a message in dash will blink 5 times to confirm that programming mode is finished. id it doednt blink, simply repeat last two steps, push start button with key to light dashboard, push start button again to let the dash go off, push unlock, then lock. dashboard will confirm.
    remember to start with no keys in car, and no more than one key inside the car in any given time during programming.
  9. #7
    Nov 2010
    Truecode lists the Leaf.
