Results 1 to 15 of 29
    richiebb's Avatar
    Aug 2015
    Argentina
    Default Question and Request for HPL Orange5 Scripts
    Feb 2015
    congratulations on what you are doing
    here are scripts, some have mistakes
    can you fix it I will be grateful to you
  3. The Following 6 Users Say Thank You to neverseenpotato For This Useful Post:
    datapage (18th April, 2021), gilbert250 (30th October, 2023), ives muniz (15th April, 2024), ledong (17th April, 2018), richiebb (9th April, 2018), yahia1908 (10th April, 2018)
    richiebb's Avatar
    Aug 2015
    Argentina
    Quote Originally Posted by neverseenpotato View Post
    The scripts are correct!, Probably created for other versions of Orange (previously)
    I will give you an example.
    RED : show route, CHIPtype->file->script
    GREEN : shows the code block that does the job of calculating the code
    everything before the green block is the reuse of the chip file BR9010.hpl that is in the folder C:\Program Files\"ORANGE_DIR_PATH"\HPL
    which is the configuration of the mentioned chip
    solution?!...... update the chip configuration!!
    ; DEH.hpl
    ; Orange programmer module CarRadio ; CHIP=Rohm BR9010,64x16
    SOCKET=2
    PINO=CS,2
    PINO=CLK,0
    PINO=DI,1
    PINO=WC,3
    PINO=RBI,4
    PINI=DO,1
    CDELAY=2
    [INIT]
    R5=$VERSION
    R5=&0FFF000H,R5=>>12
    R7=280,R7?!R5{EXIT}
    WC=1,RBI=1,CS=1,CLK=0
    [READ]
    CS=0
    CONST=10101000B
    LOOP=CONST(7,0){DI=I,CLK=1,CLK=0}
    LOOP=ADR(0,7){DI=I,CLK=1,CLK=0}
    DI=1,LOOP=DATA(0,15){CLK=1,I=DO,CLK=0}
    CS=1
    [WRITEINIT]
    WC=0,CS=0
    CONST=10100011B
    LOOP=(7,0){CLK=1,CLK=0},CS=1
    [WRITE]
    CS=0,CONST=10100100B
    LOOP=DATA(0,15){DI=I,CLK=1,CLK=0}
    P=10000,CS=1
    [WRITEEND]CS=0,CONST=10100000B
    CS=1,WC=1
    [Code]
    ADR=0,R5=DATA,ADR=1,R6=DATA
    R5=&0FF00H,R5=>>8,R7=R5,R5=&00FH,R5=<<4
    R7=&0F0H,R7=>>4,R5=+R7,R5=<<12
    R7=R6,R8=R6,R7=&00F0H,R6=&0000FH,R6=<<8
    R8=&00F00H,R8=>>8,R6=+R7,R6=+R8,R5=+R6
    PRINT=("Код: %04lx",R5)
    everything marked in blue should be replaced by
    ; BR4090.hpl ;file is the one that uses the orange 5
    ; Orange programmer module v3.3
    ; (c) 2000 Alex Plusov, Victor Makcimov
    ; CHIP=Rohm BR90X0 series
    ; CHIP=BR9010,64x16;BR9020,128x16;BR9040,256x16
    ; tested BR9020F
    SOCKET=2
    PINO=CS,2 ;1
    PINO=CLK,0 ;2
    PINO=DI,1 ;3
    PINO=WC,3 ;6
    PINO=RBI,4 ;7 input - not used
    PINI=DO,1 ;4
    CDELAY=2 ; one set delay (1 MHz Max!)
    [INIT]
    [READ]
    CS=0
    R0=10101000B
    LOOP=(7,0){DI=R0[I],CLK=P} ; start+READ opcode
    LOOP=(0,7){DI=ADR[I],CLK=P} ; out adr
    DI=1
    LOOP=(0,15){CLK=1,DATA[I]=DO,CLK=0} ; read data word
    CS=1
    [WRITEINIT]
    WC=0 ;enable write
    CS=0
    R0=10100011B
    LOOP=(7,0){DI=R0[I],CLK=P} ; EWEN opcode
    LOOP=(7,0){CLK=P} ; empty
    CS=1
    [WRITE]
    CS=0
    R0=10100100B
    LOOP=(7,0){DI=R0[I],CLK=P} ; start+WRITE opcode
    LOOP=(0,15){DI=DATA[I],CLK=P} ; write data word
    P=10000 ; tE/W 10 ms max
    CS=1
    [WRITEEND]
    CS=0
    R0=10100000B
    LOOP=(7,0){DI=R0[I],CLK=P} ; EWDS opcode
    CS=1
    WC=1
    you must do this in all scripts that do not work.
    CFG File Explanation
  5. The Following 3 Users Say Thank You to richiebb For This Useful Post:
    ives muniz (15th April, 2024), ledong (17th April, 2018), neverseenpotato (19th April, 2018)
  6. #4
    Feb 2015
    yes,scripts are correct and work with old Omega.These are remande for Orange 5 but some of them make errors.Thank you very much for the corrected script,i'm going to try to remake the others with similar errors.
    Your tutorils for coding are really useful.
    Can you make a script,which changes the VIN and fixed crc - for example rd4.Thanks
  7. The Following User Says Thank You to neverseenpotato For This Useful Post:
    richiebb (19th April, 2018)
  8. #5
    Trstenik - Thun
    Quote Originally Posted by richiebb View Post
    ; DEH.hpl
    SOCKET=2
    PINO=CS,2
    PINO=CLK,0
    PINO=DI,1
    PINO=WC,3
    PINO=RBI,4
    PINI=DO,1
    CDELAY=2
    [INIT]
    R5=$VERSION
    R7=280,R7?!R5{EXIT}
    [READ]
    CS=0
    CONST=10101000B
    CS=1
    [WRITEINIT]
    WC=0,CS=0
    CONST=10100011B
    [WRITE]
    P=10000,CS=1
    CS=1,WC=1
    [Code]
    ; tested BR9020F
    SOCKET=2
    PINO=CS,2 ;1
    PINO=CLK,0 ;2
    PINO=DI,1 ;3
    PINO=WC,3 ;6
    PINI=DO,1 ;4
    [INIT]
    [READ]
    CS=0
    R0=10101000B
    DI=1
    CS=1
    [WRITEINIT]
    WC=0 ;enable write
    CS=0
    R0=10100011B
    CS=1
    [WRITE]
    CS=0
    R0=10100100B
    CS=1
    [WRITEEND]
    CS=0
    R0=10100000B
    CS=1
    WC=1
    Your thread is very helpful ,thank you for that!
    these new scripts can be made much simpler
  9. #6
    richiebb's Avatar
    Aug 2015
    Argentina
    Quote Originally Posted by mikroel View Post
    It can be made much simpler
    Thanks mate I did not know that in this language they can include files.
  10. #7
    Trstenik - Thun
    Also,it will be very interesting to show how we can make .HPX file form .HPL
  11. #8
    richiebb's Avatar
    Aug 2015
    Argentina
    I'm new with this language, but from what I was researching, only those who participated in the cncLabs project know what encryption is like
  12. #9
    Trstenik - Thun
    I have made many scripts for airbag,dash and radio, but all is in .hpl format .
  13. #10
    richiebb's Avatar
    Aug 2015
    Argentina
    ask him: zalupentiy
  14. #11
    Trstenik - Thun
    ask him: zalupentiy
    he know how to make .hpx files?
    in the mean time here one more NEW script for radio ULVWNFZ20
  15. #12
    richiebb's Avatar
    Aug 2015
    Argentina
    yes mate.
    He worked on the CnCLab project for orange5.
    His name is Pavel Mazur and also known as Pavel-Pervomaysk
  16. #13
    Trstenik - Thun
    yes mate.
    Maybe he would like to share some manual for making scripts or sample scripts and for .hpx
  17. #14
    richiebb's Avatar
    Aug 2015
    Argentina
    I already asked him ...... he still does not answer
  18. #15
    zalupentiy's Avatar
    Nov 2014
    Canada
    This examples looks antion & not actual for real time.
    I didn't fart,my ass like you so much it just blew you a kiss.
