Did you test it can copy to jmd king chip?
Is worth to swap HB for KD-X2?
I did some cloning tests with the Kd-X2.
Hi, the JMD-KingChip did not work.
The JMDD-M640 = worked.
Cn2 = worked
Cn3 = worked
Cn5 = worked
lkp02 = it worked
Remote NBMultifunction = It worked
Note: The cloning of 4D and 46 does not work if you do not have internet connection. But the process is very fast.
I have tried to generate some remotes with the function SIMULAR DEVICE, and they work perfectly.
Some functions are not yet available. However, the team seems stable, and promising.
For me Keydiy is a brand that has good development and support.
I will gladly wait activations of new functions.
[SIGPIC][/SIGPIC]
autoTkey (15th May, 2018), gkinz (17th May, 2018), HeXeN (14th May, 2018), miloudmess (30th December, 2018), PocketHero (14th May, 2018), pongsky (23rd November, 2018), rob h (14th May, 2018)
Hi,what is the coverage for remote renew,i can not find any list for that.
Hi friend... Not Available, sample: "Coming Soon"
[SIGPIC][/SIGPIC]
newone (14th May, 2018)
igorr (18th May, 2018), musti418 (31st May, 2018), PocketHero (17th May, 2018), pongsky (23rd November, 2018)
Hello hcip... My kd-x2 can not read id64 transponders. Can your team read them?.
Thank you in advance for answering
[SIGPIC][/SIGPIC]
ALBERTO_ (18th May, 2018)
Upgrade to version 4.6.1
and stopped recognizing the kd-x2 device via Bluetooth.
Reinstalling the App did not solve the problem.
I managed to solve it in the following way: (Android):
1. OFF bluetooth phone.
2. Restart phone.
3. ON Bluetooth phone.
I hope it helps some of you.
Regards.
[SIGPIC][/SIGPIC]
BeatsByMe (13th July, 2018), electrobop (19th May, 2018)
I upgraded to 4.6.1 and didn't have any bluetooth issues.
Might have been your phone/device?
Hello every one, I am new to this forum, I have already introduced myself earlier, what is your experience with this device in regards to rolling code remotes, is it able to copy and work with these type of systems? Also can it unlock locked crypto ID48 chips? Thanks in advance for your help.
Hello faisalhusain007, I commented that the remote cloning options with rolling code, makes them in the "Remote clone - Special copy" function, and although the KD-X2 does it apparently, in fact the control created "DOES NOT WORK". At least the ones I've tried.
As for if you unlock the id48, I just did the test and unfortunately could not unlock it (Error code: 82).
I recommend downloading and install the app to view the functions that are active.
I describe to you what functions if they have worked for me and what not, so that you can get an reference.
REMOTE FUNCTION
A) REMOTE GENERATE:
Remote Generate = if it works
Old-Nb-Zone = if it works
Remote Search = if it works
B) REMOTE CLONE
Normal copy = if it works
Special Copy = failure, of 10 Rolling Code Aftermarket that tries to clone, the 10 failed, not working.
Remote re-make = fails, it worked in 1 out of 12 tested remotes, but it has many options to edit a remote and you can save it to create it later.
C) REMOTE DETECTION
Frequency test = if it works (Ask, Fsk and Infrared).
Data checking = if it works (interesting)
Data compare = if it works (interesting)
Smart Match = Disabled
D) REMOTE EDIT
Edit by IC = Disabled
Edit by remote = Disabled
E) OTHER
My remotes = If it works (save your remotes created in option B) "remote re-make")
Generated Records = If it works (saves the remotes created from option A) "Remote generate and Old-nb-zone")
CHIP FUNCTION
1) CHIP CLONE
Automation Detection Clone = If it works (It does not detect the Dst 4E transponders). I have successfully cloned 4d, 4c, 46. I used successfully JMDD-M640, Cn2, Cn3, Cn5, lkp02 and Remote NBMultifunction, It only works with active internet. JMDKingChip not Working.
Toyota G Clone = I have not tried it yet
48 clone chip = Disabled
2) CHIP GENERATION
Toyota G chip generation = I have not tried it yet.
Chip generation = if it works, and it is used with the NB-Multifunction Remotes. (generates pcf7936, pcf7946, id11, id12, id13, id47 / 38)
Id33 / 40/41/42/44 = if it works (I have only tried id40 and use a blank pcf7935).
48 Chip Generation = Not working (tp22 failed, tp23 failed, tp24 failed, tp25 failed, Jetta Dedicated failed, Fiat failed, all mark "error code: 81").
3) OTHER
Remote Unlock = Version 4.6.2 ALREADY AVAILABLE. I have not tried it yet.
Ignition coil detect = if it works.
I want this information to help you.
Respectfully: ALBERTO_
regards
[SIGPIC][/SIGPIC]
faisalhusain007 (22nd May, 2018), HeXeN (22nd May, 2018), PocketHero (22nd May, 2018)
48chip.jpg@ALBERTO_
Thank you really appreciate your help, I got my hands on a unit here today to take a quick look, I tried on a number of immo chips and remotes had success with most of the immos, but couldn't get most of the rolling remotes to work, as for the 48 ID chip it says it cant be copied. Thats the one i really need to get working. I managed to pull the eeprom of the ECU, and used Code wizard pro dump the pincode, would it be possible to unlock the immo with that pin code? Again thank you for your patience I am trying to learn and figure things out, I do read a lot but sometimes there just isnt enough information out there, or I cant find what i am looking for.
