Page 2 of 45 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 673
  1. #16
    metalik's Avatar
    Mar 2012
    Nice to known.
    Wysłane z mojego Redmi Note 3 przy użyciu Tapatalka
  2. #17
    norman1967's Avatar
    Dec 2015
    Amsterdam
    I would like to know
    KEYDIY KD-X2 can it make virgin PCF7946 id46 as found I opel Astra H keys?
    And what are the differences (function) between it vvdi Key Tool V2.2.2
    Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
    4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
  3. #18
    Oct 2015
    Poland
    Astra H uses pcf7941, on vectra c you got pcf7946
  4. The Following User Says Thank You to klesk1986 For This Useful Post:
    norman1967 (21st April, 2018)
  5. #19
    khalcdi's Avatar
    Jun 2009
    hi,
    which chip using for cloning CN1/2/3 , TPX2/3...
  6. #20
    Dec 2010
    Nottingham
    im told it can clone to CN Chips , LKP chips and jmd handy baby chips
  7. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    doctore (21st April, 2018), khalcdi (21st April, 2018)
  8. #21
    Jun 2017
    US
    When you say remote copier it will copy car remotes like for dodge? If not is there a tool that can copy remotes like that?
  9. #22
    metalik's Avatar
    Mar 2012
    My tool arrived. First look its nice, chip read fast, remote frecuency test work good. Its have one interesting function, simulate remote by tool and android app.
  10. #23
    norman1967's Avatar
    Dec 2015
    Amsterdam
    Quote Originally Posted by metalik View Post
    Do tell is more as you test. I am wondering of it can clone ford proxy keys to another ford proxy key or if we must use there keys?
  11. #24
    metalik's Avatar
    Mar 2012
    You cant copy proxy key, keydiy work to make universal proxy key.
  12. The Following User Says Thank You to metalik For This Useful Post:
    norman1967 (24th April, 2018)
  13. #25
    norman1967's Avatar
    Dec 2015
    Amsterdam
    What would you all say is the main differences in the new kd v the vvdi key tool?
  14. #26
    metalik's Avatar
    Mar 2012
    Quote Originally Posted by norman1967 View Post
    For now key tool is better to chip copy, kd-x2 precode many remote. I use both now and i am weiting for update on kd soft.
  15. #27
    norman1967's Avatar
    Dec 2015
    Amsterdam
    So vvdi key we need to buy tokens to use?
  16. #28
    Dec 2010
    Nottingham
    vvdi key tool you need tokens for id48 96 bit cloning , tokens are $8 each , handy baby now use tokens for 96 bit as well which are alot dearer .
    speaking to kd , they havnt made the decision yet on tokens or how much tokens will be for 96 bit id48 .
    keyline use no tokens but the gkm chips are £15 .
    silca use no tokens and silca 48 currently around £12 for the id48 chip ( rumours of their about to go up in price )
    both above clone in just a few minutes and token free .
    xhorse vvdi key tool tokens are $8usd plus cost of chip
    handy baby cheap chip but expensive token
    at the end of the day its the speed to clone , the cost to clone and the chip price that will dictate the best tool , the token and chip prices may make silca and keyline competative as token free and very fast and reliable , time will tell.
    the cost of the machine is not a factor , the cost of consumables ie tokens and chips is far more important , as a decent saving to produce the chip will soon negate the cost of the kit , once all consumable prices are known then it becomes easier to decide on best machine .
    i have silca , keyline and handy baby options already , i have a kdx-2 on way to test for a uk distributor , soon id48 will be just another key to clone . with silca about to release ford 80 bit cloning im sure the rest will have it too in no time .
  17. The Following 6 Users Say Thank You to rapidlocksmiths For This Useful Post:
    Atex31 (7th May, 2018), nagib (26th April, 2018), norman1967 (25th April, 2018), Pan Drhola (26th August, 2020), PocketHero (25th April, 2018), ucokseparoh (25th April, 2018)
  18. #29
    dimet's Avatar
    Mar 2010
    MKD
    Someone tried id48 96 bit cloning? Just thinking which device to buy. Does KD-X2 or VVDI KEY TOOL?
  19. #30
    Newbie jozthekeyman's Avatar
    Dec 2016
    South Africa
    Quote Originally Posted by dimet View Post
    Id48 cloning is not active yet. As i heard their server is not done yet. Will be soon.
    Sent from my SM-G930F using Tapatalk
  20. The Following User Says Thank You to jozthekeyman For This Useful Post:
    dimet (7th May, 2018)
