Results 1 to 8 of 8
    mislav88's Avatar
    Mar 2011
    Default Peugeot Boxer SID208 disable dpf and egr
    Can someone please disable dpf and egr from this file?
    Thank you
    Dec 2013
    Quote Originally Posted by mislav88 View Post
    Thank you
    your request.
    Pass after Thx+rep
    DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
  3. The Following 2 Users Say Thank You to gitko For This Useful Post:
    Anass GM (31st December, 2019), mislav88 (9th April, 2018)
    mislav88's Avatar
    Mar 2011
    thank you but after a day i have P2002, can you please also disable this dtc
    Dec 2013
    Here it is the file
  6. The Following User Says Thank You to gitko For This Useful Post:
    mislav88 (21st April, 2018)
    mislav88's Avatar
    Mar 2011
    your solution is not good, car is shutting down with dtc P2428 exhaust gas temperature too high, than you have to wait 1 hour before it will start again. Same thing with all sensors disconnected
    anyone please have good solution for this car?
  8. #6
    Lithuania
    Clear errors and car will start, I'm seeking for this solution too. Resistor 10k in ext temp sensor circuit?
  9. #7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    temp sensor can be emulated in software no need resistors
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  10. #8
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    2099c8 and 209996 linearisation for sensors
  11. The Following User Says Thank You to Ignasvw For This Useful Post:
    waldi1979 (18th August, 2021)
