Results 1 to 2 of 2
    May 2013
    Manchester
    Default Audi A6 injectors Testing with Vagcom Need Help plz
    I am having issue with audi A6 2.0 tdi, it vibrates at idle sometimes and loads of white smoke in the morning, Car drive's perfectly fine and pulls really well. I heared there are issue with injectors. I have got the injectors reading with vagcom but i dont if its the good reading. Can anyone plz tell if the readings are good or bad. Thanks
    Cylinder 1: 0.79
    Cylinder 2: -0.47
    Cylinder 3: -1.20
    Cylinder 4: 0.85
    Jul 2016
    Vilnius
    The readongs alone means absolutely nothing.
    If this is a PD engine, I would start with replacing ALL the injector seals, hold down bolts and injector lash adjustment. Very common problem.
    * MK100
