Citroen Xsara Picasso 1.8 does not ignition after the battery is down
Results 1 to 2 of 2
    Sep 2012
    Default Citroen Xsara Picasso 1.8 does not ignition after the battery is down
    Hello!
    Citroen Xsara Picasso 1.8 gasoline 2000 turns on the starter but does not ignition. It is kept for two days with the battery down and then does not fire, contact is in, the starter rotates, no current to the pump! Is it possible to forget the key and not to activate the immobilizer?
    I stuck it with Lexia, one of my mistakes shows an unrecognized transporter. Attach a photo with the errors found, please if someone has encountered a similar problem, let me help!
    If it turns out to be an immobilizer, is it possible to disable it-immo off for this car?
    windy1603's Avatar
    Jan 2009
    Flat battery can often wipe key codes from BSI. If you turn on IGN then turn off and leave keys in IGN when you open the drivers door. If there is no bleep the keycode has been lost and you need to recode keys
