lishi pick to pick and decode the ignition if the 10 cut key
my lishi tool is 2in1, only door and trunk. this is my problem, key with 10 cut but i only take the 7 of the driver door.
how have you got the 7 cuts ? by stripping door lock ? and what are the 7 cuts you have ?
and have you tried tool in ignition to see if all wafers are felt ? what lishi are you using ?
Send the code
Sent from my SM-G930F using Tapatalk
put here what code u read from door lock and i will give all 10 wafers
The code that i read from lock is 2 4 2 4 2 2 1 _ _ _
try code 50706 , direct cuts : 2242422113
drivers door normally has cuts 2 to 8 with positions 1 , 9 and 10 missing according to instacode , so you will have got from door _2424221_ _
carsandkeys (13th April, 2018)
Code work 100% how you get the code? my insta code 2014 is different and not give me the code.
The second problem. I try program the key with sbb, and T-300. T-300 program new keys, access gained. but show error. I try with 7936 transponder. i try with zed full too but he asks me for a PIN code. I'll try to generate it with vvdi and it asks me to read a 93c56, it's from the ecu, right?
I read the ecu.
Magneti marelli MJD 6J0 EEprom 95320. Someone can give me pin code?
Here dump.
Hi you find your pin code ? Or want . Have opel calculator maybe same after test for you
Envoyé de mon SM-G935F en utilisant Tapatalk
after check not same opel have external box for immo , read this and give your pin code , or use IOterminal , maybe find code pin , not work on dump tool juste reading on obd ,
swift on 05 is a cross over between 2 systems , old 4c system uses a set pin code of 0895 on swift , the id46 system uses set pin code of 0408 normally on swift , most good programmers know the preset pin so no need to enter , if your machine is asking for pin code it should be one of these 2 pins.
with regards the key code , you said your code was 2424221 _ _ _ , so looks like you entered the known cuts into instacode in positions 1 to 7 which is why instacode found no code , try entering your known cuts in positions 2 to 8 leaving 1 , 9 and 10 blank in find bitting , so , _ 2424221 _ _ and it should give you correct code , as the door lock has just 7 of the 10 cuts in positions 2 to 8 on the key and not 1 to 7.
nenadgorgi (14th April, 2018), rob h (15th April, 2018)
This is ID 46, the other swift that i programed the programmers do all, no pin code. but this time with t-300 or sbb show error when i try program this, whit skp i try with 4 generic pin that the programmer give to me, 0895,.... Then i try with zed full but this ask to pin code, i try with 0895 and show invalid pin code maybe this have a problem with immo. the engine es 1.3cdti
if id46 , the pin should be 0408 , you can also try 9622 , can also try 9905 though this was later id40 model normally .
rob h (16th April, 2018)
