Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by rapidlocksmiths View Post
    if id46 , the pin should be 0408 , you can also try 9622 , can also try 9905 though this was later id40 model normally .
    I try 0408 in Swift 2011, doesn't work. Try 9622 work, it's same as Vitara 2009 i've did before.
  2. #17
    rob h's Avatar
    May 2011
    This type, runs from 2004-2010.
    Is there a European version, and Asian?
  3. #18
    Aug 2013
    Spain
    Is european versión, i try 0408 and 9622 without success.
  4. The Following User Says Thank You to carsandkeys For This Useful Post:
    rob h (16th April, 2018)
  5. #19
    Dec 2010
    Nottingham
    you can try 9905 for diesel models as well but beware that some of these are id40 chips make sure it isnt an odd id40 chip if getting just error on some machines , 5244 on some petrol models is also used.
    ad100pro and mvp pro should bypass pin
  6. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  7. #20
    Bllinda's Avatar
    Baltic
    Are you sure that the pin has four digits?
    Quote Originally Posted by carsandkeys View Post
    This is ID 46, the other swift that i programed the programmers do all, no pin code. but this time with t-300 or sbb show error when i try program this, whit skp i try with 4 generic pin that the programmer give to me, 0895,.... Then i try with zed full but this ask to pin code, i try with 0895 and show invalid pin code maybe this have a problem with immo. the engine es 1.3cdti
    P.S. After three attempts ....
    today
    A topic that interests me
  8. #21
    Aug 2013
    Spain
    I try all methods. I send the car to official service, this have cut wires into bcm and obd. thanks to all
  9. #22
    Bllinda's Avatar
    Baltic
    The official service will replace the new bcm and program keys
    today
