bmw dump file for LM2 module unit 3451529 lear x3 AHL
Results 1 to 4 of 4
    Dec 2017
    italia
    Default bmw dump file for LM2 module unit 3451529 lear x3 AHL
    ciao ragazzi, mi chiamo Paolo dall'Italia, ho un problema con bmw x3 e 83 xenon
    l'unità di controllo luci malfunzionante, anabbaglianti e abbaglianti sempre accesi e l'indicatore di svolta a sinistra lampeggia sempre, comunico i dati della mia centralina e invio tu i miei file, qualcuno può riparare i file o inviare lo stesso file?
    grazie mille e mi dispiace per il mio inglese
    Buona giornata a tutti
    CAUTION I HAVE SOLVED THE PROBLEM, THE FILES IN THE ANNEX ARE NOT CORRUPTED
    Mar 2011
    Vilnius,Lithuania
    disconnect front and rear suspension level sensors and press thanks
  3. The Following 2 Users Say Thank You to xyznia For This Useful Post:
    durdur (5th October, 2023), ricards99 (28th April, 2018)
    hi all,
    did you solve your problem, i have same module with nothing work
    thank you
    Dec 2017
    italia
    Hi, I managed to solve, check if all the suspension level sensors are working. I know it's strange but believe me, the defect was solved by the dealership bmw, it was not the light module
  6. The Following User Says Thank You to pdisavino For This Useful Post:
