Results 1 to 12 of 12
Thread: Corsa d
    Default Corsa d
    2013 reg. A1.3dtc engine code. Ecu is faulty. Obtained a reset one. Is there any tool which can program this Ecu. I no mdi2 online will do it. But can I use any other tool. Thanks
    Aug 2011
    Spalding
    Genuine vauxcom shoudn't be a problem.
    Will vauxcom program it offline
    Aug 2011
    Spalding
    Vauxcom does nothing online.
    So you saying it program this 2013 reg car Ecu offline
    Aug 2011
    Spalding
    It's not a new (Blank ECU) only a reset one.
    To be 100% sure mail Derek at Ilexa.
  7. The Following User Says Thank You to MJRVR For This Useful Post:
    radiosolutions (22nd April, 2018)
  8. #7
    I programmed new Ecu,but the fault still there. Egr fault open circuit. I tested all wires back to Ecu,all are fine.
    With ignition on voltages are
    white/violet. 4.338
    violet/black 011.1
    white. 006.8
    brown/black. 005.8
    brown/red. 5.018
    can anyone help
  9. #8
    Meat-Head's Avatar
    So if you actuate it does valve make farting clinking noises?
  10. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    radiosolutions (27th April, 2018), super jumbe (2nd May, 2018)
  11. #9
    Aug 2011
    Spalding
    Quote Originally Posted by radiosolutions View Post
    white/violet. 4.338
    violet/black 011.1
    white. 006.8
    brown/black. 005.8
    brown/red. 5.018
    can anyone help
    What does Tis say about that fault code?
  12. #10
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Swap immo eeprom
  13. The Following User Says Thank You to super jumbe For This Useful Post:
    Meat-Head (2nd May, 2018)
  14. #11
    Tried to actuate the egr. It tells me to start car to actuate,but nothing happens. No change in engine. No eeprom in this Ecu.
  15. #12
    Meat-Head's Avatar
    What about live data, poke egr with big wooden stick , and voltmeter
