Do these ECU by boot. Very easy to open and no problem with tricore protection
Hola
ECU BMW e60 edc17cp02
HW 0281015043
SW 1037394079
Tengo un problema al cargar OBD, cualquiera de los modelos exportados de mis ganadores resulta que no arranca y siempre tiene que cargar el ori o un mod de una compañía conocida.
¿Alguien tiene la idea del problema?
puedo pasar los archivos por MP
saludos
Autotuner user
Kess/Ktag
WinOLS
caillou (15th April, 2018)
your problem is chcecksum.
Hello
I have a problem loading for obdII any mod exported from my winners it turns out that it does not boot and it always has to load the ori or a mod of a known company.
does anyone have any idea of the problem?
can i pass the files by MP
regards
Please DONT TOUCH Car's when you dont know how to do!!!
Sent me ecu id and i post full tricore
Verstuurd vanaf mijn SM-G955F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
alcorte
your problem is checksum.
Hello
with what program can I correct the checksum for this ecu?
Attach the image with the id ecu
Hello
all ok, modify from winols without touching the checksum then when loading fgtech v54 corrects and boots without problems.
regards
Why not Bootmode???
Its easy and Safe
make tune in winols without cs... then flashing, tool makes correct cs....
