bmw 328i ms41.0 ecu
Results 1 to 2 of 2
    Default bmw 328i ms41.0 ecu
    I have problem with my car bmw 328i 1998 I closed ok and after some days have strange problem at idle, engine vibrate and to much fuel consume .I tested using car soft and gt1 no fault code only fuel excess lambda read to all pistons .with live data I see incorrect camshaft value -13 kw normal value is -5 to +5 .I changed camshaft with new one oem bmw also all coil I have 4 air mas flow .i have check camshaft wires are ok.if i remove cashaft i have no change to engine also to live data.
    Jul 2020
    SPAIN
    Hola ... si usted metio diagnosis y no salio ningun problema ... su problema puede ser un manguito de aire/admision
