Results 1 to 7 of 7
Thread: Smart W450
    Dec 2015
    Portugal
    Default Smart W450
    Smart W450, customer have 2 remotes and both stop working.
    Program again remotes, car starts now but remotes don't work.
    Try program new remote, but same situation.
    Car starts, but door lock don't open / close.
    Any idea what is the problem?
    Enviado do meu MI 6 através do Tapatalk
    Tools: AVDI, Im608, VVDI 2, VVDI MB, T-Code, SBB
    Eeprom: VVDI Prog, Orange, Tango, TMPro, R270, ABPROG
    Other: VVDI Mini Key Tool, Key Tool, KD-X2
    Electronic key machine: Silca Triax, Idea, Unocode
    rob h's Avatar
    May 2011
    Immo goes by remote, so if car starts, the remotes are fine.
    Do the blinker lights in the dash light op, when you press the remote?
    Look at all the fuses, and check the sam plugs.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    the small electric motors (one in the left and the another in the right door) are broken.... It happens when the central loocking is going crazy, when the immo makes problems... and they get too much electricity...
    sometimes also at the backdoor and fuel cover....
    In any case see fuse 16 (15A) in smart before 2003... or fuse 31 (30A) from 2003....
    Dec 2015
    Portugal
    I try to program again remotes. Usually just press remote button twice, but still don't work (painel led don't start blinking) so i press again and again and it recognise the remote. I try with a new one and is the same. Just after press three or four times, led start blinking assuming remote is program.
    After, i try and remote works, but most the times, just when press second or third time the remote button car open /close doors.
    Any idea?
    Birmingham
    Reciver relay underneath centre/handbrake panel.
  6. The Following User Says Thank You to MarkPRP For This Useful Post:
    lmqcatarino (23rd April, 2018)
    Dec 2015
    Portugal
    Quote Originally Posted by MarkPRP View Post
    Already thought about that. The problem is only original parts is available, and is expensive.
    But i will try it. Thanks
    Dec 2015
    Portugal
    Job done. It really was the relay/receiver.
  9. The Following 2 Users Say Thank You to lmqcatarino For This Useful Post:
    MarkPRP (11th May, 2018), rob h (11th May, 2018)
