here you go
Hi guys!
Could someone can help and make this file swirl flaps and dpf off?
I know how to make dpf off correct for other sw but this one is different.
Ecusafe and volta ar bad because deleting most of dtc table.
Opel Zafira EDC16C39 / 0281014024 / A50316
Thanks!
here you go
flashtech (17th April, 2018)
Maybe someone can help with swirl flap problem?
johak tried to help, but no luck at the moment (BIG thanks to him).
Swirl flaps and actuator are unplugged and there is limp mode and errors P2075 and P0660 appear - however, they are deleted in file.
If someone have solution please help. ORI file is in first post.
I have, good emulated in maps and work. Dtc off never work in this car.
FILE SERVICE
I do dpf and flaps, wait 20 minutes
FILE SERVICE
pass pm, write
FILE SERVICE
flashtech (25th April, 2018)
Thanks!
Writing now. Will update post when done.
EDIT.
Car is still in limp mode, can rev it till 2000rpm. And there is still errors P2075, P2279 and P0660
what tool did you use to write BDM?
K-TAG. Never had problems before.
Now I watch the match, then I will do v2
FILE SERVICE
try this......
FILE SERVICE
if you want try this
Thank You very much guys! I will try in the morning and then will update this post.
