SVRL before a torque limiter. easy to find, br.
Hello
Does anyone know how to make popcoen on Fiat/Alfa /GM 1.9 16vCR .
I tried to limit it with TL at 4500=X NM 4505=0 NM but it pops very slowly and not like the SVRL popcorn on Vag Edc15
Should I try that on NM to IQ conversion or from specific gear torque limiter?
I'm running out of ideeas since general TL rev limit behaves very bad and it feels bad.When it cuts the rev it ,the car stops pulling in a brut manner.
DSG TUNING
File Service
JTDperf (21st April, 2018)
I did not find and svrl like on edc.Does edc16 have one?
Searching 5300 or so does not bring anything in hexdump
svrl in this ecu is probably 5500
DSG TUNING
File Service
no sign of SVRL,here is the ori file.
ost 5500/5300 values are mostly axes and nothing to look like SVRL EDC15.
Do you have any ideea?
You can do it using torque limiter maps or nm to iq or both
As i said from the start,I have tried both but they work very slow and all I have got is a squirling timing belt and a ruined belt tensioner from TL Limit.
The NM to IQ works only once and then it stops.
I've seen that EDC16 vag has a SVRL near Injection Duration or at the end of it that is set 5300 by default.But the Alfa/GM/Fiat CR doesent have a SVRL or am I wrong?
Set the gap to 1rpm in TL and it will be faster, I've done a lot of edc16s this way no problems...
nbtechnic (16th January, 2020)
https://imgur.com/a/bFVm2
It is running like this .Have I done it wrong?
Try SVRL at 1CBC84
AKH84 is correct
i tell you
DSG TUNING
File Service
Yes ,indeed was above the TL .Only that 5400 rpm seems odd,but it works like it should.
Thanks a bunch guys !!!
