Results 1 to 5 of 5
    Member kimiz's Avatar
    Dec 2015
    Default SAAB 93 1.9DIT(AT) Engine stop after shift change
    Hi guys,
    I have problem with car:
    Saab 93 1.9 dit 2007r automatic transmission
    Engine stop in few seconds after change gear to "D" (only D), but communication between modules ecu/abs/esp/cim is lost at once
    DTC
    - Ecu: no communication with abs/cim
    - Cim: no communication with ecu
    Etc...
    Any ideas?
    Senior Member maybach_'s Avatar
    EU
    Check the wiring between ECU and UCH
    Be allways Thankfull!
    Does the engine shudder to a stop ( lock up clutch engaged )
  4. The Following User Says Thank You to autotrans For This Useful Post:
    Meat-Head (20th April, 2018)
    Dec 2015
    Quote Originally Posted by maybach_ View Post
    Checked, wires and pins is ok
    Quote Originally Posted by autotrans View Post
    Yes, but only on "D". When i add some gas, the engine goes stable and does not go out
    when I add some gas, the engine goes stable and does not go out
    I assume this is a six speed aisin warner transmission and from your description the engine
    rev's drop only in the drive position. do you have a scanner where you can
    read live data
