Lexus is200
Results 1 to 8 of 8
Thread: Lexus is200
    Default Lexus is200
    2007 reg. Battery went flat.so jumped off another car to start it. Now have problem with indicators.horn.washers.central locking button on drivers door and remote key not working.if I disconnect battery over night and put back on.all work again for about 5 mins then all stop again. I tested all fuses and replaced drivers side module but still the same.can anyone help
    Meat-Head's Avatar
    Is no idea a good enough answer, check all fuses first
    Jul 2013
    yorkshire
    Did you put sidelights ON before connecting cables? It protects against spikes.
  4. The Following 2 Users Say Thank You to autoden For This Useful Post:
    Meat-Head (30th April, 2018), radiosolutions (27th April, 2018)
    All fuses checked
    Apr 2016
    You need to re-program the scanner
    What do you mean by reprogram the scanner
    Meat-Head's Avatar
    Quote Originally Posted by radiosolutions View Post
    Would guess saying needs immboliser, keys etc recoding
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
    radiosolutions (11th May, 2018)
  10. #8
    May 2018
    try to do a hard reset; ignition off, disconnect bat+ and bat-, connect the cables together for 20 min. all computers or ecu will reboot
