Results 1 to 1 of 1
    Feb 2014
    Default PASSAT B6 2006 2.0TDI BMP strong engine vibrations
    Hello everyone!
    Passat B6 2.0TDI BMP, bought with dpf off, egr off and some more power. The car has a very strange problem, vibrations in neutral gear when the car ride at small speed, when braking at the lights. When the car stops vibrations in a few second stoped too.
    This is not a problem with suspension and not with flywhell.(flywhell is changed)
    Attach VCDS log -when vibrations, Injection Quantity in group 001 jumps too.
    Maybe problem with ecu dump and consequences of chiptuning? I read dump with kess. Can you see if everything is ok?
    Thanks !
