With what tool you precoded key?
he forgot to make precod before learning
read 9386 put in programer to make precod and then u can learn in the car
I read epprom 93c86 and i make precode and learn in the car with abrites but remote no work
bad remote. try another remote sh oem and move only 7946
i make precode with tm100 and learne with diagnostic delphi i change the remote but no work
the chip has coded in but not the remote , so will be just 1 of 2 issues normally ;
1) you are using the wrong remote , i have seen only delphi on these but ive spoken to some who have had marelli remote on late combo ( same as doblo ) though most and all ive done have been delphi .
2) more likely is you havnt precoded the remote , you have precoded the transponder if car starts but not the remote control , very few machines succeed to precode the remote control , abrites with fn017 licence , zedfull and TMpro 2 with correct licences are all that i know of that do this correctly , tango and most others do not properly precode these
rokibar (21st April, 2018)
i keep forgetting miraclone , my bad i should have known that peter and lockdecoders would have cracked this too , so miraclone will precode these too.
if you have original avdi with FN017 licence , you should be able to whole job by obd with no need to use a dump tool , avdi does these by obd and precodes remote all in just a few minutes , just prepare correct remote , 8 smd if oem marelli , or 10-16 smd if aftermarket marelli and delphi remotes .
ive not had abrites fail on one of these by obd yet , seamless and quick.
and as has been said tango doesnt precode the remotes , so tm100 wont either .
use um pino de 5 dígitos, escreva via obd com t 300, x 100
Send me the file, I'll get the pin
he has the pin code already and he has succesfully precoded the transponder and coded the transponder to the car , it is the remote he cannot prepare and code as hasnt been prepared by his kit .
Excuse me for my stupid question.
The old key have the remote?
I ask you because some doblo' haven't remote closing function.
Only manual centralised door lock.
If the van came without remote key, check with Vin if your van have remote option.
I have coded several remote (also china) without problem.Precoded with Tmpro and AVDI.
Cheers
yes tmpro and avdi will precode the remote , the tm100 he used will not
key learnt by abritus with remote precoded by tango
