Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Thanks,but there's no start,another solution?
I've got 2 errors
immo and internal error
your dump off
JurajJurajj (21st June, 2020)
You got to short 2 wires in Pats plug for crank the car
My work is my life ART TECH GARAGE
car is not here now,but i will try this in few days and let you know,thanks SHMORTZ
this is 100% working solution, I have waist many days trying to do off on that version, this ecu don't work even with emulator, you need to remove immobox and short K and W wires to be able to make diagnostic.
geomesh (24th April, 2018), mexanico1971 (24th April, 2018)
I'm sure you've found the right solution,i've tried dozen modifications of N1 93c46,tried to ,to mod hc05 in immo box,tried vag emulator and nothing so far,tough version..
Do what Shmortz says
Shmortz (24th April, 2018)
Hi, please could You send me pass?
THX
@Shmortz
Please make it off also here
Same number ecu as upper...
Uplaoded 93c46
Or if someone have tested solution for this ecu to upload
your dump off
bugarcek (10th June, 2019), kv2 (13th January, 2021), mexanico1971 (30th December, 2020), Pyromaniak (30th April, 2020)
Hi, same car same ecu can i use the immo off dump file or i have to send my original and help me out?
post your ori dump
Hi guys
Can somebody help me with the same car, same ecu?
Eeprom attached
Thanks!
