Results 1 to 5 of 5
    Nov 2011
    EU
    Default Fiat ducato 3.0 egr +flap off
    I need fuill solution for throttle body off p0638
    TVA disconnected
    Nov 2011
    EU
    With this solution car does not show errors, but car is in limp mode because of TVA... But it is totally new one fitted.
    Wires are not problem.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Bad tva solution, and then with unpluged goes to limp mod
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Nov 2011
    EU
    Can problem be in ecu?, because tva in totally new. But dtc can not be erased even on ignition
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Flash this, let the tool to correct the checksum...
    Disconnect the plug from the TVA!
    Regards!
  6. The Following 4 Users Say Thank You to bobolin4o For This Useful Post:
    bugarcek (20th April, 2018), diagauto741 (21st April, 2018), figani (20th April, 2018), pike (20th April, 2018)
