Results 1 to 8 of 8
    Feb 2010
    Default Passat judder/missfire @3000 rpm
    Hi guys. Hopefully someone will make an educated guess regarding my Passat, 1.9 tdi, BKP engine.
    I'm experiecing judders while driving at about 3000 rpm, mostly in 4th,5th and 6th gear. Below and above that rpm there is no problem.
    Now, the things i've done to try and remedy this:
    -checked vaccum lines and pump pressure - ok
    - recently changed turbo
    - changed gaskets in tandem pump
    - changed fuel and air filter
    -checked fuel tank pump for obstruction - ok
    - egr valve cleaned and working
    - changed air intake flap
    -changed MAF with new one
    - also i've got NO fault codes
    Feb 2010
    Even a guess would work, as I'm out of ideas.
    Maybe any injector/connections with fault.Measure all
    Aug 2015
    Check the camshafts, especially on the intake side. Worn out camshafts are a plague in b-series engines
    Jul 2013
    yorkshire
    Did it have this problem before turbo change?
    Meat-Head's Avatar
    Was talking to local toilet cleaning attendant, he was saying there is a real common on bkd for this, and rumor states map it out some how
    Jul 2013
    yorkshire
    Are you sure its a missfire? The dm flywheel can cause juddering etc
    Meat-Head's Avatar
    Quote Originally Posted by autoden View Post
    I agree with you, rumor states millions of results on INFERIOR websites, but unable to confirm
