Now solution for this ?
Report back.
Best regards.
Dragon
darius89 (22nd April, 2018)
Hi, still have errors
Address 15: Airbags Labels: 5K0-959-655.clb
Control Module Part Number: 5C0 959 655 AB HW: 5C0 959 655 AB
Component and/or Version: AirbagVW10 501 0976
Software Coding: 00004245
Work Shop Code: WSC 00066 790 00455
ASAM Dataset: EV_AirbaVW10SMEVW360 001030 (VW32)
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72EA576CA57BC5D68C-8026
2 Faults Found:
9444100 - Front Passenger's Front Airbag Crash Sensor
B101B 04 [137] - Internal System Fault
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 1793 km
Date: 2012.14.00
Time: 04:41:26
10485908 - Internal Control Module Memory Check Sum Error
B2000 94 [137] - Unexpected operation
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Check this ...
Best regards.
Dragon
How is gone ?
Best regards.
Dragon
|Hi
The file is it protected?
File is asking for password.
