Results 1 to 7 of 7
    Jun 2012
    Default Renault Scenic 1.9 edc16c3 egr off
    Hi to all. Someone can help me to remove egr from Renault Scenic 1.9 ecu edc16c3 with egr disconnected? Attached the link to the file. Thanks to all!scenic.txt
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Quote Originally Posted by cawadany View Post
    here is manual for this ecu.
    free for everyone, just use thanks and rep.
    regards.
    DSG TUNING
    File Service
  3. The Following User Says Thank You to maajkii For This Useful Post:
    VortexVGX (21st October, 2020)
    Jun 2012
    I have it. But I prefer a solution with disconnected egr if it's possible.
    Jun 2012
    Quote Originally Posted by maajkii View Post
    regards.
    Tested this solution with egr connected. Not works. Egr works, checked from diag tool.
    maajkii's Avatar
    Mar 2017
    ok, what dtc do you have after disconnect? post it and i help you later.
    DSG TUNING
    File Service
    johak's Avatar
    try with this, disconnect egr!
    Jun 2012
    Quote Originally Posted by johak View Post
    No dtc but limp mode.
    But I solved by myself.
