Your clear.
Your clear.
Hi I test your file. In airbag module no errors now but still on dash I can see check start and stop system. Are you sure that file is good ? I asking because I have 2 times problem with dacia the same ecu. When file in airbag where not good start and stop system not working. In car I haven't any errors.
I scan car by DDT2000 and in parameters START & STOP is crash detected. That is the problem someone know to clear this ? Also don't work steering lock.
Try and report, clear errors, switch ign off for 15 sec, switch ign on, clear errors again and done ...
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
Check this, pass the same, report back like I said ...
Best regards.
Dragon
