Hi all, im after some help please, im in search for a paired bin file/s for a Vauxhall Corsa CD40 USB and GID.
I have both stereo and display but wont pair with each other, both have been divorced/reset and i cannot seem to
pair them together, well the stereo will program but the display wont pair to the EHU.
The ident for the EHU is FB 13407108
The ident for the DIS is TA 13381204
If some one could help it would be appreciated greatly
Bought them both second hand, and the scrap yard where i got them from said they reset the screen and display, which iv checked and its correct.
Both in delivery state.
Fitted to my car, went though the procedure but cannot get them to pair, so i though it load a paired bin file and try it that way?
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Ok cool il give that a try no its tech2win with a mongoose gm2 passthur
Its a genuine pass thru that vauxhall allow to use
Check for Mid Speed Can Bus Settings, it should be the same for EHU and DIS.
Also, you can post dumps here to check if it's divorced.
CD40 USB - 24c32
GID Delphi - 25080
danielif (19th June, 2023)
Thanks, i have check the dumps and they are correct all divorced, just wont pair!!
I have an error code for the display, B1000 which on a Corsa D is an eeprom problem!
Try leeching a pair of matching dumps
If i have a bin file for a GID and EHU if the pass codes are the same, will this work?
advice check mid can and variant config they need to bee the same i'm sure on Cd40usb midcan and variant config it's write Mobile phone present
LE: next time when someone ask you for help,help him http://www.digital-kaos.co.uk/forums...C-Needle-Sweep
shooting (30th May, 2018)
tryplex92 (1st June, 2018)
