Results 1 to 3 of 3
    Apr 2018
    Default Easytronic !!!!!!
    Hi all, can anybody answer my question ?
    I have a 57 plate Astra h 1.6(xer) sxi with the dreaded easytronic box . The clutch actuator has failed and 2 repair companies have told me it is not repairable.i have op com and can reprogram a second hand unit.although I can find second hand units none are Virginised or have original pass code from donor vehicle.
    My question is...does the donor unit NEED to be Virginised or have pass code or will op com reprogram unit to my car with my pass code ???
    Hope SOMEBODY has the correct answer so I don't waste anymore money.
    Sent from my SM-G930F using Tapatalk
    Apr 2013
    Search Flash + Eeprom AM29F400BB + ST24C16, for example ...
  3. The Following 2 Users Say Thank You to 2xded For This Useful Post:
    gogoli (1st September, 2022), Stelaras26 (18th May, 2018)
    Nov 2009
    Spain
    Hi M8,
    There are two options, make reset with his own car pass and program with opcom and car´s car pass.
    Option 2, just clone with IO Terminal or other tool which support this gearboxes..
    Regards.
    Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
    Worldwide assistance.
    All brands, All vehicles, All files.
