what ecu it is? iaw6lp1.xx?
Hi guys,
I need immo off and virgin file please.
HW 9654792980
SW 9654210380
My ecu is defect i brought this ecu second hand and i want to use it in mij car. my car is 307 sw petrol 2004 automatic this file i get it with Ktag boot line. HW and SW numbers are from the old defect ecu. Please help me
boylonden (24th April, 2018)
if yes. its no immo off solution. use virgin. then mach again with bsi use old pin code. i will help you. but now im still on road
this is your ecu virgin file. actually you can swap dump st10f to new ecu. but sometimes broken ecu, has no good dump. your car may be dont running normally, i suggest you to use my virgin dump in your another thread
btw, your pin is N688
Thank you for your help i will try and let you know if its working.
is this file for iaw 6lp1.xx and your car is it benzin 2,0 liter and automaat
yes it is for rfn engine (ew10)
i think its no different automatic or not. you can configure wit pp2000. but yes, i use for 307 sw AT
boylonden (27th April, 2018)
Thanks a lot i writ your file with kess in stf10 and now i m triying to install pp2000 then i can configure the ecu
