Results 1 to 14 of 14
    Apr 2017
    Default problem MERCEDES C203
    Hello
    I have a problem
    I own a Mercedes C203 from march 2003
    Since about 4 days my car does not start anymore, the key turns in the neiman all the lights come on
    I bought new kits (.Ezs; Elv, ecu, cle) but no demmmarage with key
    Thank you for your help.
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Hi.
    Look at this, it's something similar.
    http://www.digital-kaos.co.uk/forums...ght=w203+start
    Apr 2017
    OKY MAN THANKS <3
    Apr 2017
    I read all the comments but no solution
    http://www.digital-kaos.co.uk/forums...ght=w203+start[/QUOTE]
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Look Drive Autorization.
    Post the trouble codes.
    and with this we can get the fault.
    Apr 2017
    Quote Originally Posted by bladymir View Post
    when Î make thé diagnosis hé gives me this code:B1000 (EZS calculator DÉFECTIVE)
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Quote Originally Posted by ayoub laghrissi View Post
    this code appeared with new ezs?
    Apr 2017
    yes brother unfortunately
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Hello
    How are your mercedes?
    Apr 2017
    Hey man wathsp ? nothing the problem is not solved, tell me ? how to rewrith flash with xprog
    Hello
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    To re-record flash with x prog you need to have the Motorola 908 solder panel, do not ever read the flash internally in the ezs with x prog. You have to have the flash file read by x prog and dump it into your motorola. The flash is the same of two microcontrollers. The truth is that Etl is the best solution.
    Apr 2017
    thinks broo the probelem solved <3
  13. #13
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    I'm glad
    Tell us how you solved the problem?
  14. #14
    Apr 2017
    I'm glad
    I reprogram ezs with das
