give this a go....
please help with mileage 93c86 inside
22K.rar
old = 22000 ml
new = 4307 ml
thanks in advance
give this a go....
akravtsiv (22nd April, 2018), ascrap2003 (22nd April, 2018), GameTheoryOptimal (27th May, 2018)
Thanks for help
Could you please calculate 034707 miles for a 2016 civic the customer came to me with no eprom in her dash the previous corrector lost the chip in the street Thank you very much
That's what happens when people are cheap and get the $80 guy to work on their car. 2016? Try 2.5-3 times that amount
lexidime (27th May, 2018)
yes and according to the customer he's MIA now! Not picking up his phone. The chip is not even that much. Got to love the drama from time to time
GameTheoryOptimal (27th May, 2018), lexidime (27th May, 2018)
you convert it to km I need miles thanks
So the customer came in today and I popped in the new 93c86 with the Dump I got from this post.I powered up the cluster and the reading is 56000 instead of 34757 I think it just a simple KM TO miles conversion issue with that.
I told her to just buy a used cluster from the junkyard because her gauges are all damaged + her cluster display has deep scratches on the background matting she was able to get a good cluster but the miles are too high 44866 miles
it needs to be 34757 miles can any one help Me Thanks!
Ok here are some tips is you ever come across a 2016 Honda civic
1) You will need to remove the Radio + AC Controls + Glove box trim plate + GPS Antenna + lower dash Panel+ Center Counsel side panels all clips and a few Philips head screws.
2) There are two dash version! One has the 93c86 On the top and the other has the 93c86 on the bottom (I confirmed 93c86 NOT 93c76) {Don't remove Any Needles the pads are on the top} for both versions
3) 5 volts works on both version 3.3 volts is not needed20180527_165453.jpg20180527_165453.jpg20180527_165453.jpg
any miles between 31000 to 34757 is ok thanks in advance
2016 Honda Civic 34752...
lexidime (28th May, 2018)
He also took the customers deposit. and from the description of the tool he used to try to do the correction i'm assuming that it's a digiprog3
