Results 1 to 7 of 7
    Newbie tmaciejs's Avatar
    Mar 2012
    U.K
    Default Ford Galaxy IMMO OFF - BOSCH 0281 011 143 - 038 906 019LR
    Hi All member I have Ford Galaxy 1.9 - 2002
    I need to yours help turn off IMMO with my ECU eprom 2404 flash dump . I will be happy if somebody help me.
    Jul 2012
    hi
    offffffffff
    Mar 2012
    U.K
    Hi Junnior and thank you for heplp but your files is damaged save ok but not possible unpack and open.
    Nov 2015
    Quote Originally Posted by tmaciejs View Post
    Archive OK, mate! Just update your Winrar and you'll be able to unpack!
    Mar 2012
    U.K
    All OKAY - Thanks stefyhgs
    for help
    all works fine ( updated WINRAR - I go quickly checked ) write dump on my eprom and I will fast back and inform.
    Mar 2012
    U.K
    All work well and car start running. Thanks for yours help.
    Sent from my SM-N910F using Tapatalk
    Feb 2018
    hi
    Power loss and degraded mode
    audi q5 03L906022ER
    dtc
    No. VAG du calculateur: 03L 906 022 ER Mat: 03L 906 022 B
    Pièce et/ou version: R4 2,0L EDC H01 4390
    Codage logiciel: 01210002180F2820
    Code atelier: WSC 06335 000 00000
    Jeu de données ASAM: EV_ECM20TDI03L906022ER A01006 (AU48)
    ROD: EV_ECM20TDI03L906022ER.rod
    VCID: 79F9BC38F8CCCFF61A-802C
    4 Codes défaut trouvés:
    4875 - Pompe 2 de liquide de refroidissement
    P261A 00 [039] - Coupure
    Non Confirmé - Testé depuis RàZ mémoire
    4799 - Débitmètre d´air massique (G70) Signal trop faible
    P0102 00 [039] - -
    5380 - Soupape de volet de dérivation du filtre à air (N275) Rupture
    P1016 00 [039] - -
    4892 - Soupape de recyclage des gaz (N18) Dysfonctionnement
    P0403 00 [167] - -
    Témoin allumé - Non Confirmé - Testé depuis RàZ mémoire
