You need to read immo data from orig cluster and write it to target cluster. You need specialized tools for this. Reading eeprom won't help because immo data is stored encrypted unique for each cluster.
I bought cluster with full fis (873B) and want to install it in my car.
I have eeprom reader, but when I red about this on forum someone is mentioning about read flash? As I am not introduced in this, can some one advice me how can I swap this clusters?
Breket (23rd April, 2018)
Ok. Which tools do I need?
Do you mean immo data is in Flash or?
Immodata is stored im eeprom but it is encrypted. You need to read flash to get the key for decryption.
More easy for you to find somebody to do the swap. Tools are way to expensive for just swapping one dash
I have CARPROG 8.21 (need rework) can it do that?
Also, I plan to buy FVDI clone (still investigating which one to buy), I have plan to do keys for VAG 2000-2010, so any advice on this also would be appreciated.
I guess both Carprog and FVDI are good enough to read/write immo data from these types of clusters.
Breket (24th April, 2018)
But what with encryption? Would carprog do it by itself?
My carprog 8.21 is not working. I red that I need to change some components. Until I figure this up, I order CH341A 24 25 Series EEPROM Flash BIOS USB Programmer + SOIC8 Clip On-Board because I have some RCDs to decode.
Can this programmer help in swap?
If you have a tool which can read/write immo, it will handle encryption already.
(So I am not talking about reading/writing eeprom, but I am talking about immo!)
Breket (25th April, 2018)
You don't need to do it manually. Most tools will do it all for you. They will simply read or write immo regardless of how it is done behind the scenes. I have no personal experience with Carprog ...
VVDI2, Smok X-dash , AVDI is very good tools for this.
FVDI and Car prog clone should do the job but it may give you problems as well.
Also with X-Prog it can be done, if you read flash and eeprom, but only micronas dash.
The question is , it is original dash Visteon or Micronas?
yugo45 (1st May, 2018)
