Results 1 to 14 of 14
Thread: Bmw f020
    Dec 2015
    Portugal
    Default Bmw f020
    My first F series. F020. Have working key. Follow the guide but something was wrong and at the end, couldn't program new remote. Big problem, now car don't start. Any suggestion? Should i rewrite Fem eeprom with original file?
    Enviado do meu MI 6 através do Tapatalk
    Tools: AVDI, Im608, VVDI 2, VVDI MB, T-Code, SBB
    Eeprom: VVDI Prog, Orange, Tango, TMPro, R270, ABPROG
    Other: VVDI Mini Key Tool, Key Tool, KD-X2
    Electronic key machine: Silca Triax, Idea, Unocode
    drugowaz's Avatar
    Mar 2015
    Lithuania
    What tool you used. Procedure fem program was succeefull?
    as you add key only when fem is already programmed. In this way imposible to brick the car
    Dec 2015
    Portugal
    Quote Originally Posted by drugowaz View Post
    Avdi. The procedure was all ok until the last step (aproach new remote to key reader next start button).
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Than contact avdi support.
    I dont know how avdi but other tools if key not adeed you wont brick fem. Original eeprom you already wrote in last step before add key .
  5. The Following User Says Thank You to drugowaz For This Useful Post:
    lmqcatarino (23rd April, 2018)
    Dec 2015
    Portugal
    I read DTC's and give some errors. All of them says to "renew LRR control unit"
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I this not many use avdi for fem here . Maybe nobody.
    What support sais?
  8. The Following User Says Thank You to drugowaz For This Useful Post:
    lmqcatarino (24th April, 2018)
  9. #7
    Dec 2015
    Portugal
    Problem solved with help from abrites Spanish dealer.
  10. The Following User Says Thank You to lmqcatarino For This Useful Post:
    drugowaz (24th April, 2018)
  11. #8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    So share solution.
  12. #9
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by lmqcatarino View Post
    Why you asking for help here and when you get help you write only 'problem solved' ? If you ask for help, get ready for share solutions also. That's how forum work
  13. The Following User Says Thank You to p1et For This Useful Post:
    bersch8688 (5th May, 2018)
  14. #10
    Dec 2015
    Portugal
    Quote Originally Posted by p1et View Post
    I know that. But it wasn't easy, and i didn't get very well what was the solution. It was remotely. I could see they rewrite ECU from backup files from Avdi twice. But that didn't solve the problem. Just after that they did something that I couldn't get it.
  15. The Following User Says Thank You to lmqcatarino For This Useful Post:
    p1et (24th April, 2018)
  16. #11
    Fallen's Avatar
    I'm guessing it did not restore the FEM coding correctly.
    AVDI saves this before it does the downgrade.
  17. #12
    Dec 2015
    Portugal
    Ok. The problem was the new remote wasn't the correct. I go with right remote 868mhz, clean DTC's and both remotes work's. Job done.
  18. #13
    p1et's Avatar
    Oct 2013
    Car stopped working with original key after you programmed additional key with wrong freq? How is that make sense
  19. #14
    Dec 2015
    Portugal
    I add new key, first put customer remote on Protag after por new remote and then approach new remote to the key sign on car, but Avdi says "invalid remote type".
    I cancel the procedure, and after that, the original remote didn't start the car because several DTC's that couldn't be erased.
    Go back and program remote with correct frequency and now finish the procedure, erase DTC's and both remotes work.
  20. The Following User Says Thank You to lmqcatarino For This Useful Post:
    p1et (4th May, 2018)
