Results 1 to 4 of 4
    honingkoning's Avatar
    Dessert
    Default Marelli iaw 5NF. T1 interchange
    Guys can i change a Marelli full hybride ecu from a Clio 1.2 16v with a half hybride ecu from same car.
    Can i make it virgine (with good key) Will it auto adapt.
    Or should i read hybride eep and write it to normal eep in half hybride ecu.
    Thank Guys.
    Dessert
    Some one Guys
    levisdj's Avatar
    EcuLand
    As I know from Fiat 1.6 16v Marelli 5NF T1 can be virginised via obd with abrites fiat software with ignition off for two minutes the BCM will auto adapt it... not sure about renault thow...
    Dessert
    Quote Originally Posted by levisdj View Post
    Sorry made a mistake, ecu is 5NR.T1.
    Wbr Adam.
